Rene Paul Huet
Beginner
LMS 4.2 Fault Monotor
I useLMS 4.2, In fault Monitor I have the folowing messages :
Event_Description
StateNotNormal
Device IP
10.92.8.142
Device Type
Switches and Hubs
Fault Last Updated At
17-Nov-2013 12:36:25
Component
PWR-I@/2058 [Sw2, PS1 Faulty, RPS NotExist]
Component Class
PowerSupply
Component Event Code
1085
Event Category
Environment
Event Source
DFM
Status
CRITICAL
cisco Env Mon Supply State
6 --> I have just 4 (not 6)
But when I check in thw switch everything is ok :
#sh env all
FAN 1 is OK
FAN 2 is OK
FAN PS-1 is OK
FAN PS-2 is OK
SYSTEM TEMPERATURE is OK
System Temperature Value: 30 Degree Celsius
System Temperature State: GREEN
Yellow Threshold : 46 Degree Celsius
Red Threshold    : 60 Degree Celsius
SW  PID                 Serial#     Status           Sys Pwr  PoE Pwr  Watts
1A  C3KX-PWR-715WAC     LIT170517XR OK              Good     Good     715/0
1B  C3KX-PWR-715WAC     LIT1705180V OK              Good     Good     715/0
2A  C3KX-PWR-715WAC     LIT170517UY OK              Good     Good     715/0
2B  Not Present
3A  C3KX-PWR-715WAC     LIT170518XH OK              Good     Good     715/0
3B  Not Present
SW  Status          RPS Name          RPS Serial#  RPS Port#
1   Not Present     <>
2   Not Present     <>
3   Not Present     <>
#sh stack-power de
Power Stack           Stack   Stack    Total   Rsvd    Alloc   Unused  Num  Num
Name                  Mode    Topolgy  Pwr(W)  Pwr(W)  Pwr(W)  Pwr(W)  SW   PS
SP-1                  SP-PS   Ring     2860    31      669     2160    3    4
Power stack name: SP-1
    Stack mode: Power sharing
    Stack topology: Ring
    Switch 1:
        Power budget: 943
        Power allocated: 223
        Low port priority value: 20
        High port priority value: 11
        Switch priority value: 2
        Port 1 status: Connected
        Port 2 status: Connected
        Neighbor on port 1: Switch 3 - 7cad.7416.0680
        Neighbor on port 2: Switch 2 - acf2.c5c1.4600
    Switch 2:
        Power budget: 943
        Low port priority value: 22
        High port priority value: 13
        Switch priority value: 4
        Neighbor on port 1: Switch 1 - 4c4e.359b.c900
        Neighbor on port 2: Switch 3 - 7cad.7416.0680
    Switch 3:
        Power budget: 943
        Low port priority value: 21
        High port priority value: 12
        Switch priority value: 3
        Neighbor on port 1: Switch 2 - acf2.c5c1.4600
        Neighbor on port 2: Switch 1 - 4c4e.359b.c900
I don't find any bug for this ussue.
someone has an idea?
Many thans for your help
1 ACCEPTED SOLUTION
AFROJ AHMAD
This seems to be a BUG ,there are few alredy filed for 2960's and 3750's.
CSCtx16194    C3750 stack switches ciscoEnvMonSupplyState returns notFunctioning
CSCuj56140    SE5:Power supply status is wrong when dual power supply is removed
CSCti27620    SNMP trap and snmp walk don't reflect correct status for power supply
CSCtq97867    SNMP Generating "Faulty" status for Power supply when PS is inserted
this is a device side issue.
Thanks-
Afroz
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
1 REPLY 1
AFROJ AHMAD
Thanks-
Afroz
Content for Community-Ad
