LMS 4.2 , how to find the Critical issues
Ibrahim Jamil
Level 6
Level 6
in LMS 4.2 how to delete the alarms mentioned in right of the LMS Window
2)how to see if something wrong or critical issue happened on cisco devices let say FAN Goes bad on ur 7200 , when you open the lms on the morning
thanks
jamil
Marvin Rhoads
If you're new to LMS, I recommend referring to all of the very thorough end user guides (posted here).
Specifically, your questions are covered in the Fault Monitor chapter of the Monitoring and Troubleshooting guide.
Hi Marvin
Pls post me links for any users
thanks
You're welcome Ibrahim.
My posting above includes hyperlinks. They can be a bit hard to see in the CSC postings so here they are in long form:
User Guides:
http://www.cisco.com/en/US/customer/products/ps11200/products_user_guide_list.html
Fault Monitor Chapter:
http://www.cisco.com/en/US/customer/docs/net_mgmt/ciscoworks_lan_management_solution/4.2/user/guide/lms_monitor/mnt-faultbrowser.html
Hi Marvin
i receive the below
Forbidden File or Application
