LMS 4.2 issue with Nexus 7k and Nexus 5k
david de sousa
Beginner
Beginner
                   Hi guys,
i'm working with Cisco Prime LMS 4.2.0, i have a problem to manage Nexus series, the switchs are well discovered but i can't fetch config, view ports, the modules not presents int the chassis are all in error. when i add the devices, every L3 interfaces are added as a separate switch. The User tracking doesn't work through the Nx (but it seems it's normal for UTU as i saw)
So, my question is :
Is it normal to have trouble with Nexus on LMS ?
There is a way to fix this?
thanks
David
Vinod Arya
