LMS 4.2 not processing syslog messages
MARK GRABER
I have a new install of LMS 4.2 on a virtual appliance.  No syslog messages are getting into LMS.  They are being received by the server, but are showing up in /var/adm/CSCOpx/log/dmgtd.log, and aren't getting processed by SyslogAnalyser.
Here's the syslog.conf file:
     local6.info        /var/log/ade/ADE.log
     *.info;mail.none;news.none;authpriv.none;cron.none;local0.none;local1.none      /var/log/messages
     authpriv.*        /var/log/secure
     mail.*        -/var/log/maillog
     cron.*        /var/log/cron
     *.emerg        *
     uucp,news.crit        /var/log/spooler
     local7.*        /var/log/boot.log
     #Application LMS Generated config
     #BEGIN CSCOmd - DO NOT EDIT THESE COMMENTS OR CONTENTS CONTAINED WITHIN - local0 1
     local0.emerg;local0.alert;local0.crit;local0.err;local0.warning;local0.notice;local0.info;local0.debug  /var/adm/CSCOpx/log/dmgtd.log
     #END CSCOmd DO NOT EDIT BEFORE THIS LINE  1
     local7.info  /var/log/syslog_info
My guess is that the incoming messages are getting written to the wrong file.  What do I need to change to correct this?
Emperor2000
Hello there Mark.
I have the same problem also running a virtual appliance but cant get the sysloganalyser to process it.
Since we are vealuating this software its kind of hard to get a TAC case going also.
Try to configure the devices to send the syslog on the 'default' local7
Use the Netconfig template for syslog
Cheers,
Michel
I found that all of my syslog messages were being captured under /var/log/messages.  This was due to my Cisco devices being configured with "logging facility local5".  Instead of reconfiguring all of my devices to log to facility local7, I just changed the following line in syslog.conf and restarted (/etc/init.d/syslog restart)
Before:
After:
local5.*  /var/log/syslog_info
Probably not the best way to do it, but it worked for me.
-Rick
