LMS 4.25 - Remote-Migration from old LMS 3.2 to LMS 4.25
lo.mueller
Hi all,
unfortunately I'm not able to restore old backup-data from LMS 3.2 to LMS 4.25 (which was possible until LMS 4.2). with restorebackup.pl.
Is there an hack available to convert/restore old data from LMS 3.2 to LMS 4.25?
Environment is Solaris.
Thanks for any update
Lothar
AFROJ AHMAD
Hi Lothar,
AFAIk, database restore can be possible Only to LMS 4.2 from 3.2 , you can restore directly to 4.2.5
You need to restore the backup on 4.2 first and then proceed with upgrade.
http://www.cisco.com/c/en/us/td/docs/net_mgmt/ciscoworks_lan_management_solution/4-2/install/guide/install/dmg.html#17503
Thanks-
Afroz
***Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
