LMS and time
Wassim Aouadi
Level 4
Level 4
On LMS 3.2, time is one hour ahead, despite that it's set correctly on the host Windows machine.
Any idea?
Nael Mohammad
Level 5
Level 5
Search the Windows registry to see if the timezone is defined correctly for this key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\TimeZoneInformation\TimeZoneKeyName". The value should be your time zone and not emptyp.
I checked that registry values. It shows "Romance Standard Time":
I checked on Control Panel. The date, time and timezone are correct:
Why does LMS still show a different time and timezone?:
