Dears,
I config LMS to manage many network devices with the same credential. However, only the Nexus 7000 fail to be archive configuration. LMS log said during telnet, the authentication fail 3 times. (I didn't use any authen server. The username and password are local. and in DCR page, i only configure "
Primary Credential"l, nothing in "Auto Update Credential")
Then i do a CAD check and fail also. I open the RME/CAD log, comparing with those successful log, there is one line different:
[ Mon Mar 05 16:04:27 SGT 2012 ],WARN ,[main],com.cisco.nm.rmeng.inventory.cda.CdaFacade,getCdaHandlerIf,163,CdaAG is not implemented for the device145.240.152.1
What does it mean "CdaAG is not implemented for the device??? Or what should i do?
Thank you for your help in advance!!!!
Best Regards
Lian Qi
