10-12-2011 10:42 AM
i am sending syslog messages from our ASA's to an LMS prime. Somehow the messages are not showing up in syslog_info. I tested shutting down LMS and using 3com daemon syslog server on a device with same ip address as the LMS host and the syslog messages were displayed.
All ASA's are managed by LMS.
any ideas?
regards
alex
03-08-2012 05:42 AM
oh, yes
facility 23 on ASA/PIX is equivalent to Local7, during default facility on ASA is 20 (Local4)
Thank you Alex for your help
I have different problem with Cisco Prime and ASA 8.4: Change Audit reports different 'User Name' from which is actually did config change - maybe you had same issue with your ASA?
Best regards,
Leszek
03-08-2012 05:48 AM
Sorry,
we stopped using Prime to manage Firewalls. We use Cisco Securtiy Manager instead.
regards
alex
