LMS Prime: Syslog messages from ASA are not precessed
alex.dersch
Level 4
Level 4
i am sending syslog messages from our ASA's to an LMS prime. Somehow the messages are not showing up in syslog_info. I tested shutting down LMS and using 3com daemon syslog server on a device with same ip address as the LMS host and the syslog messages were displayed.
All ASA's are managed by LMS.
any ideas?
regards
alex
16 Replies 16
oh, yes
facility 23 on ASA/PIX is equivalent to Local7, during default facility on ASA is 20 (Local4)
Thank you Alex for your help
I have different problem with Cisco Prime and ASA 8.4: Change Audit reports different 'User Name' from which is actually did config change - maybe you had same issue with your ASA?
Best regards,
Leszek
Sorry,
we stopped using Prime to manage Firewalls. We use Cisco Securtiy Manager instead.
regards
alex
