LMS2.2 - ANI Discovery not complete ?
mbilgrav
Level 3
Level 3
on win32 server we have LMS2.2.
I have put in appr. 180 Seed devices, mostly remote MPLS sites.
My discovery doesnt discover the MPLS LAN, just the seed device ??
If I telnet to the router and issue sho cdp nei, i see the devices there. SNMP etc are correct.
Also I have one switch were my CallManagers are in, aswell as some IPPhones.
The CCM are not discoverd, nad no phones eighter ??
What to do ?
kawng
What do you have configured for
Server Configuration->Setup->Ani Server Admin->
SNMP settings?
Individual entries for each ip address or using
ip ranges with wildcards?
If you have different SNMP strings configured for all your devices, you need to put individual
entries, if you are using the same SNMP strings for
all your devices, then use the wildcards
Example:
If your network is 10 ip address space, then in
SNMP Settings, enter your target as:
10.*.*.*
Since these are remote sites, you may want to
increase the SNMP timeouts and retries
Make it 10 for timeouts and 3 for retries
Do you have any devices show up in Topology Services->Network Views->Unconnected View
is your network all Cisco Devices?
Hope that helps
I use wildcard for snmp.
plz note all routers ARE discovered ! and I have edited the config on them with netconfig, inorder to enable CDP in the first place.
I have all the routers as unconnected in Topy-Serv.
and YEZ - It all Cisco... or unmanaged boxes, like hubs
mbilgrav
Level 3
Level 3
ok, so today I enabled debugging and trace for the topology in ANIserver.
Very interesting !
Tells me why the IP Phone and CCM are not discoverd:
2005/05/03 16:08:16 Discovery ani TopoSMFGenerateCdpTopology: No device found for IP address 10.35.42.4 - entry dropped.
same stuff goes for the phones.
How to correct this ?
I have the IDUs installed ...
