LMS3.0.1 Dez 2007 - SSO problems
dainat-bis
I installed the LMS3.0.1 Dez 2007 updates on both servers in our multi-server environment on solaris, but after that SSO and application registration don't work correctly anymore.
The LMS Server add the last DNS Hostname suffixes always twice.
E.g. the real slave hostname is nms.location.web in our application registration summary appears as slave name nms.location.web.location.web and therefor all links are corrupt.
Has anyone similar issues after installing the Dez-2007 updates ?
akemp
Level 5
Level 5
Have you recreated all of your application registrations on the SSO server ? It fairly twitchy so any time you mess with them adding an update, you'll need to recreate them.
I already tryed to recreate all applications, but everytime this strange faulty hostnames appears.
I cannot reproduce. Here is what I did.
* Accept peer certificate
* Register remote application from rtp-redwood.cisco.com with a display name of rtp-redwood.cisco.com
* All links work as they should
