Highlighted
Beginner
LMS3.2 User Tracking IP Phones Discovery Doesn't Work
I am having difficulty getting the User tracking for IP Phones to work correctly in Ciscoworks LMS 3.2.
Callmanager is version 7.1.5.10000-12.  Campus manager version is 5.2.1
  • The Callmanager publisher and two subscribers are all showing as application servers with green icons under the topology services view.
  • The callmanagers show as CDP neighbours on the switches to which they are connected.
  • I can do an SNMP walk of the ccmPhoneTable from the Ciscoworks devicecenter and get a ton of returned data.
  • The IP phones are discovered as end hosts and have mac address and IP address info when checked in the User Tracking utility.
  • Callmanager sysObjectID = OID: CISCO-PRODUCTS-MIB::ciscoMCS7835I
Any help you could give with troubleshooting would be greatly appreciated.
Rob
5 REPLIES 5
Highlighted
Enthusiast
Here is a link to the troubleshooting steps for UT and IP Phones:
http://www.cisco.com/en/US/customer/products/sw/cscowork/ps563/products_tech_note09186a0080094949.shtml#ts2d
Let me know if that helps or if you find yourself not making any progress.
Nick
Highlighted
Thanks Nick,
     I had seen that document and been through the processes
  • The mac and IP addresses of the ip phone are discovered.
  • The callmanagers are discovered and have green application server icons in the topolgy view
  • I can do an snmpwalk of the ccmPhoneTable OID and get returned data (as per this post by JClarke https://supportforums.cisco.com/message/664859#664859)
  • I can't do an snmpwalk of the ccmPhoneExtension as described in that document but I assume that since it applies to campus manager 3.2 and 3.3 that it is a bit dated and not relevant to later versions of callmanager.
I think that I have covered all the basic cdp/snmp and discovery issues.  Any suggestions on where to go from here would be appreciated.
Rob
Highlighted
Does 1.3.6.1.4.1.9.9.156.1.2.1 return any data? And could you verify that the  SNMP service is enabled? (Control Center > Feature Services > Performance Monitoring Services > Cisco Call Managers SNMP Service > Tools > Service Activation
Nick
Highlighted
Our telecommunications guys have verified that the SNMP service is enabled on the subscribers and publisher
An snmpwalk of 1.3.6.1.4.1.9.9.156.1.2.1 (ccmPhoneTable) returns results on all three callmanager nodes.
Rob
Highlighted
And new phone data is now available in user tracker. It apparently was acquired three and a half hours ago, before I asked the telecommunications guys to check the snmp service so I don't think I can blame it on them just turning it on.
I did reboot the LMS server yesterday before I went home, but apart from that nothing has changed.
It's a little bit disturbing not finding the cause, but a happy ending just the same.
Thanks for your help.
Rob
Content for Community-Ad
