08-23-2012 08:40 AM
Has anyone found a way to run inventory reports for 3750 stacks that will show the serial number, etc., for each switch in the stack? My inventory reports are way off because the master switch in the stack is the only one accounted for in the inventory report. Does anyone know how to get the 7961 ip desk phones in the inventory reports? TIA
08-23-2012 10:42 AM
I have a custom inventory report that I created called "basic device info". It just reports Device name, device type, serial number, IP address and image version. I just ran it on both a 3750G stack and on a 3750-X stack. It reports the SN for all devices in the stack.
Just for grins I ran the canned detailed device report on the 3750G stack and I see SNs for all devices in there also. What report are you running?
-Jeff
08-23-2012 11:20 AM
Thanks for your reply. I go to Report Designer > Inventory then I design the report. So far the only report I made up showed the ip address and the model. So I think I will have to play with the design features to get what I want.
