log MSG : %HA-HA_WD_LIB-6-UNREG_PROC_SUCCESS : Memory state un-registration is success
Muradazz
hi
i can see this MSG  on logs
%HA-HA_WD_LIB-6-REG_PROC_SUCCESS : Memory state registration is success
what is this   and  how  can i resolve it
on  ASR9006 Router
RP/0/RSP0/CPU0:Nov 25 02:58:06.030 UTC: config[65807]: %HA-HA_WD_LIB-6-UNREG_PROC_SUCCESS : Memory state un-registration is success
RP/0/RSP0/CPU0:Nov 25 03:00:45.504 UTC: config[65807]: %HA-HA_WD_LIB-6-REG_PROC_SUCCESS : Memory state registration is success
RP/0/RSP0/CPU0:Nov 25 03:00:49.569 UTC: config[65807]: %HA-HA_WD_LIB-6-UNREG_PROC_SUCCESS : Memory state un-registration is success
RP/0/RSP0/CPU0:Nov 25 10:42:25.933 UTC: config[65807]: %HA-HA_WD_LIB-6-REG_PROC_SUCCESS : Memory state registration is success
RP/0/RSP0/CPU0:Nov 25 10:42:37.162 UTC: config[65807]: %HA-HA_WD_LIB-6-UNREG_PROC_SUCCESS : Memory state un-registration is success
RP/0/RSP0/CPU0:Nov 25 10:43:13.306 UTC: config[65807]: %HA-HA_WD_LIB-6-REG_PROC_SUCCESS : Memory state registration is success
RP/0/RSP0/CPU0:Nov 25 10:43:18.890 UTC: config[65807]: %HA-HA_WD_LIB-6-UNREG_PROC_SUCCESS : Memory state un-registration is success
RP/0/RSP0/CPU0:Nov 25 10:43:26.781 UTC: config[65807]: %HA-HA_WD_LIB-6-REG_PROC_SUCCESS : Memory state registration is success
RP/0/RSP0/CPU0:Nov 25 10:43:57.750 UTC: config[65807]: %HA-HA_WD_LIB-6-UNREG_PROC_SUCCESS : Memory state un-registration is success
RP/0/RSP0/CPU0:Nov 25 10:45:05.741 UTC: config[65807]: %HA-HA_WD_LIB-6-REG_PROC_SUCCESS : Memory state registration is success
RP/0/RSP0/CPU0:Nov 25 10:45:09.898 UTC: config[65807]: %HA-HA_WD_LIB-6-UNREG_PROC_SUCCESS : Memory state un-registration is success
RP/0/RSP0/CPU0:Nov 25 10:45:18.736 UTC: config[65807]: %HA-HA_WD_LIB-6-REG_PROC_SUCCESS : Memory state registration is success
RP/0/RSP0/CPU0:Nov 25 10:45:30.404 UTC: config[65807]: %HA-HA_WD_LIB-6-UNREG_PROC_SUCCESS : Memory state un-registration is success
RP/0/RSP0/CPU0:Nov 25 10:45:37.466 UTC: config[65807]: %HA-HA_WD_LIB-6-REG_PROC_SUCCESS : Memory state registration is success
RP/0/RSP0/CPU0:Nov 25 10:45:41.403 UTC: config[65807]: %HA-HA_WD_LIB-6-UNREG_PROC_SUCCESS : Memory state un-registration is success
RP/0/RSP0/CPU0:Nov 25 10:46:13.863 UTC: config[65807]: %HA-HA_WD_LIB-6-REG_PROC_SUCCESS : Memory state registration is success
RP/0/RSP0/CPU0:Nov 25 10:46:19.333 UTC: config[65807]: %HA-HA_WD_LIB-6-UNREG_PROC_SUCCESS : Memory state un-registration is success
Hey!
Yes everything safe and healthy on my side, how are you doing?
Hmm. All I know so far is that the messages are generally not harmful if occuring in accordance with config commits.
I'll go through some logfiles of some ASR9001 and ASR9010 on my side, maybe I can find them randomly without commits somewhere, but so far I have never seen it.
Do you see them absolutely all the time?
If you have the oppertunity to, you can open a Case with Cisco TAC to get it investigated.
Best regards
Juls
julian.bendix
Level 3
Level 3
Hey!
The log messages are fine IF the occur in connection with a configuration commit..
If you commit a config you will always see them at the exact time the commit happens.
But in your case the seem to occur reeeally frequent.
Were there any config commits arount the time the logs oocur?
Best regards
Juls
Thanks Julian ,  hope you find well and safe  on the COVID-19
Yes  this is main router and has  many changes all the time need to commit.  but i can see the MSG many times without any activity need to commit on the memory.
Hey!
Best regards
Juls
I will double check, also I will check on other routers 9006 in the network if I see the MSG I will open a case
