01-24-2011 06:06 AM
Is there a way to do this? The info is incredibly useful when looking at it live but I am getting requests for what happened a half hour ago.
Solved! Go to Solution.
01-24-2011 07:45 AM
Yep! What syslog utility/server are you using? A lot of the syslog vendors out there offer ways to generate reports based on top-talker over a period of time. For example, take a look at the screen shot from LogZilla attached.
Rob
01-24-2011 07:45 AM
01-24-2011 07:54 AM
I think i figured it out unknowningly. We have PRTG and it has netflow sensors but I hadn't used them before. I did the setup on my device and added a netflow sensor and boom the data I want is there.
Thanks!
