Logging Discriminator
s.lachica
My logging discriminator is not working no matter how i try to modify it.
Log Buffer (128000 bytes):
*Jan 25 10:15:33.436: %SYS-5-LOG_CONFIG_CHANGE: Buffer logging: level informational, xml disabled, filtering disabled, size (128000), discriminator (NOLOG)
*Jan 25 10:15:34.325: %SYS-5-CONFIG_I: Configured from console by taskus on vty0 (10.14.0.255)
*Jan 25 10:15:33.436: %SYS-5-LOG_CONFIG_CHANGE: STANDBY:Buffer logging: level informational, xml disabled, filtering disabled, size (128000), discriminator (NOLOG)
*Jan 25 10:16:53.716: %SFF8472-5-THRESHOLD_VIOLATION: STANDBY:Te2/1/3: Rx power low alarm; Operating value: -29.5 dBm, Threshold value: -13.9 dBm.
*Jan 25 10:16:55.250: %SFF8472-5-THRESHOLD_VIOLATION: Te1/1/3: Rx power low alarm; Operating value: -28.2 dBm, Threshold value: -13.9 dBm.
CRCORML01(config)#end
CRCORML01#show run | i logging
logging discriminator NOLOG mnemonics drops THRESHOLD_VIOLATION
logging buffered discriminator NOLOG 128000 informational
My goal is to eliminate the THRESHOLD_VIOLATION on syslog (buffered). is this the correct configurations?
Son
CCIE (R&S) #27666 CCSI HP MASE
Rolf Fischer
Level 9
Level 9
what platform and IOS is it?
The logging discriminator doesn't work on some relatively recent IOS, for instance see CSCur45606.
Rolf
7 Replies 7
Mark Malone
Hey
You could try something like this as an example and then check your show log make sure its active
logging discriminator NOLOG msg-body drops THRESHOLD_VIOLATION
Hi Mark,
Have tried this one before also but nothing has changed.
Son
THRESHOLD_VIOLATION is the mnemonic field in the syslog message and not msg-body.
Hi mark
I have three servers of syslog in ASR 9010(5.1.3).
logging x.x.x.x vrf(a) severity info
logging x.x.x.x vrf(b) severity info
logging x.x.x.x vrf(c) severity info
I have a request for disable all  logs of interface Up/Down, only in server vrf(c). without changes level of severity. how could i do it?  help me please
Rolf Fischer
Level 9
Level 9
Rolf
IOS is cat4500e-universal.SPA.03.07.02.E.152-3.E2.bin
I checked and it i on the affected release.
Many thanks!
Son
According to the c4500 XE 3.7E Release Notes it should be fixed in 3.7.3E (Table 14).
Thanks for using the rating system.
