jonathan.ward88
Beginner
Lose SNMP Settings on AP reboot
Hi All,
I have 2x 2500 Series WLCs and 27 APs, at a variety of different models (mainly 2702I's)
I have enabled SNMP on the APs so as to monitor using WhatsUpGold, however when an AP goes down e.g. unplugged during testing, and then comes back up it loses the SNMP config I have set, so as far as the monitoring tool is concerned the AP is still down, until I login via SSH and re-enter the SNMP config.
I have tried a write and a copy run start on the APs but these appear to do nothing, at a guess it's to do with the WLCs providing the core config, but I can't find a way in the interface of forcing the SNMP globally for the APs.
Am I missing something, or is this expected behaviour?
current versions:
Controller Summary
Management IP Address10.25.192.133 , ::/128
Software Version8.0.110.0
Field Recovery Image Version
AP Versions
Versions
Primary Software Version
Backup Software Version
Predownload Status
Predownloaded Version
Predownload Next Retry Time
Predownload Retry Count
Boot Version
IOS Version
Mini IOS Version
Thanks in advance for any help
Jonathan Ward
1 REPLY 1
Leo Laohoo
VIP Community Legend
Nothing can be saved on the APs.  This is the foundation of controller-based AP.
If you want to pull data from the AP the do an SNMP Get/Walk on the controllers.  That's how we've done ours.
