Manage Cisco ISR routers as one device
I'm looking for a tool that allows me to manage two Cisco ISR routers (2911) as one device ("cluster" device or "virtual" device).
Both routers are connected directly to the internet and are using HSRP to perform a function of the virtual default gateway for LAN devices.
What about Cisco ASA in Active/Active or Active/Passive Failover mode?
Jernej
Joe Clarke
No, this is not currently possible.  The devices need to be managed using their individual IP addresses (i.e. not the virtual IP of HSRP).  You'll generally want to do that for the time being since both devices will have their own CPU, memory, buffer, etc. characteristics.
