06-26-2013 07:38 AM
teams administration software
· Support display 30 network devices such as routers and switches
· Display the network topology structure type tree and access to equipment from this window.
· Monitoring of switches including packet errors, temperature, bandwidth, CPU and memory.
· Alarm notification (by network errors or threshold) by email.
· Allow the computer to update the software without the need for command line usage or TFTP server application.
06-26-2013 10:58 AM
From Cisco's, all these requirements fits into Cisco Prime Lan Management Solution or now Cisco prime Infrastructure.
06-26-2013 11:59 AM
thanks for your reply.
I recommended using the Cisco Network Assistant software, which is the difference with respect to the cisco prime infrastructure.
06-26-2013 11:58 PM
CNA is a great tool and have a lot of features, but LMS/CPI is full fledged NMS application which suits all your requirements.
Following are the benefit of CNA :
Cisco Network Assistant facilitates:
Following is the benefits and features of LMS/CPI:
Cisco Prime LMS manages the deployment of the latest Cisco technologies and services such as Cisco TrustSec, and EnergyWise. Get started today with new Cisco Prime LAN Management Solution, and the related resources on this page.
There is a similar discussion in past :
https://supportforums.cisco.com/thread/180485
-Thanks
