Maximun No. of users for LMS 3.2
kmong
What is the max. number of allowed users to login in LMS 3.2 concurrently. without affectting its services?
You're right about the *supported* max of concurrent users, Michel. This is reflected in the documentation for LMS 3.2 below. The same limit applies to LMS 4.0 as well:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.2/install/guide1/prep.html#wp1354719
However, according to Joe in a much older thread, it could be possible to exceed that limit, given sufficient server resources. The LMS documentation above leaves wiggle room for that as well.
https://supportforums.cisco.com/message/693238#693238
Michel Hegeraat
Level 7
Level 7
A cisco rep. told me: 20 simultaneous users.
No documentation on this. I guess they tried it.
Cheers,
Michel
