08-18-2009 07:55 AM
LMS 2.6
RME 4.0.6
We have an MDS9134 that is failing config archive with error message
CM0056 Config fetch failed for DR-9134-01 Cause: CM0204
Could not create DeviceContext for 226 Cause: CM0206
There are no device or software updates using software center.
If is a device package problem, is there a work around for this version of RME?
08-18-2009 07:56 AM
What is the sysObjectID of this switch? The error looks like lack of device support.
08-18-2009 09:38 AM
This is what is showing up when adding the device in Common Services:
OID:1.3.6.1.4.1.9.12.3.1.3.616
08-18-2009 09:50 AM
RME support for this device is not available until 4.1.1 (LMS 3.0.1). Only Campus supports this device in LMS 2.6.
