Measure telephone traffic on an ISDN PRI
vschallenberg
Has anyone developed an EEM Scrip to measure telephone traffic on an ISDN PRI interface on a voice gateway?  Preferably the traffic measurements would be in Hundred Call Seconds (CCS) or Erlangs. It would appear that the “show isdn service” command could be used to determine the state of the individual “B” channels on the PRI.
Joe Clarke
If the "show isdn service" command gives you what you want, then you could build a policy using the timer event detector (watchdog timer) to run the command periodically and produce the desired reports.  I don't know of anyone that has already done this, though.
