MIB location for sh int counters detail for 4500?
mark.doyle
I'm having trouble finding where some stats from sh int counters detail are located in SNMP, particularly TxPauseFrames and Rx-No-Pkt-Buff (I'm checking for oversub'd ASICs).
I've found that a lot of what I could use are in dot3PauseTable and CISCO-STACK-MIB, which aren't supported.
Is anyone familiar with other tables out there that mirror some of these values?
Mark
didyap
Level 6
Level 6
Follow the URL for the CISCO-STACK-MIB, which will help you :
http://tools.cisco.com/Support/SNMP/do/BrowseMIB.do?local=en&mibName=CISCO-STACK-MIB
