MIB & OID
aneesh.ts
Can some give me good information on MIB and OID in snmp. Why it is used and how it works???
Thanks in advance
AneesH
ajagadee
Hello Aneesh,
A Management Information Base (MIB) is a collection of information that is organized hierarchically. MIBs are accessed using a network-management protocol such as SNMP. They are comprised of managed objects and are identified by object identifiers.
An object identifier (or object ID) uniquely identifies a managed object in the MIB hierarchy. The MIB hierarchy can be depicted as a tree with a nameless root, the levels of which are assigned by different organizations.
Please refer the below URL for some additional details.
http://www.cisco.com/en/US/docs/internetworking/technology/handbook/SNMP.html
Arul
*Pls rate if it helps*
