Cisco Community Designated VIP Class of 2020
674
Beginner
MIBs- where are they stored?
Hi mates :)
Are Cisco's MIB files are stored in the switch by default? or should we load them in to switch?
I ve read Cisco pdf about MIBs which says: "cisco's public MIBs are organized in to 2 subdirectories: v1/ and v2/"
But I couldnt find those subdirectories with dir all-filesystems command on my 4506 switch (IOS 12.2).
I need to learn how to get MIBs. I'll appreciate your help
tx for your help in advance
1 ACCEPTED SOLUTION
Highlighted
Collaborator
Re: MIBs- where are they stored?
MIBs are already present in the device IOS. You can use the CLI command show snmp mib to see the listing on the device. If you need to download v1/v2 MIBs for your external applications like HPOV etc, you can get them from: http://www.cisco.com/public/sw-center/netmgmt/cmtk/mibs.shtml
2 REPLIES 2
Highlighted
Collaborator
Hall of Fame Guru
The subdirectories referred to are on Cisco public ftp server. See ftp://ftp.cisco.com/pub/mibs/
If you use the tool rmushtag referenced, it will steer you to the MIBs your device(s) use and allow you download via http. The ftp site is for "power users".
Hope this helps, Please rate helpful posts.
Content for Community-Ad
July's Community Spotlight Awards
