I have just installed a new Prime Infrastructure Server and have discovered our list of guest user accounts from the discovered Controllers. We are implementing ISE 1.3 and would like to move all the guest user accounts from Prime to ISE without doing it manually. Is there a way to either export or pull the guest users from Prime or the WLC and import them to ISE?
I would be very interested to find out if this can be done.
Cheers,
Tom
