01-31-2019 02:31 AM - edited 01-31-2019 02:34 AM
hello all,
Is it possible to monitor the cisco gateway via MIB or OID? How could we do this?
01-31-2019 04:25 AM
- Depends , what hardware model/type are you talking about ?
M.
01-31-2019 06:05 AM
VG310 Analog voice gateway
01-31-2019 11:25 PM
MIBS supported are referenced in the link below and or could be used and or uploaded in your snmp manager software :
M.
02-01-2019 02:07 AM
02-01-2019 07:55 AM
Yes, but it will require more manual work as to deciding what you want to monitor , from which specific MIB using the check_snmp plugin.
M.
02-04-2019 01:33 AM - edited 02-04-2019 11:57 PM
Thanks for the reply. When I ran snmpwalk -v -c Public example.com i get lots of MIB and OID's. But I just wanted to check status of PRI. so check_snmp can do this? How could i start. Also I wanted to monitor the connectivity from other host.
02-22-2024 03:57 PM
did you find the solution to monitor vgw?
02-01-2019 02:11 AM
