01-29-2015 05:48 AM
Hi everybody. I have some issue with cisco Prime Infrastructure 2.2. We use this product in our network for monitoring network devices and I need to monitor also our ASA 5550 device with soft 8.4. I added ASA to Cisco PI but see only basic component like my device can reachable via and read via snmp. But cannot see CPU, RAM, Device ENV like Temperature, l2l vpn connection, Interfaces status and Utilization that interfaces, cannot see sub interface that placed on ASA like that g0/0.20. I need fully monitor ASA and See logs and trap for my device:
CPU RAM ENV (Temperature), Interface and sub interface status, L2L VPN Status.
1 Cisco Prime infrastructure can full support ASA for monitoring and logging.. IF YES how can i configure that features in Cisco PI 2.2 for ASA
2 IF not which product Can full support that features for full monitoring and logging ASA devices
I have a little deadline for finishing
thanks everybody before
02-04-2015 10:10 PM
no one can help me in this direction ???????
02-05-2015 06:38 AM
Hi elnurh,
Here is the link to the supported device list for Prime 2.2.
For the ASA 5550s it appears that you need 9.1.(2) code for more support from Prime. We have one of our ASAs being monitored through PI 2.1 currently and it has limitations as well with the 9.1.(2) code on the ASA.
05-06-2015 06:23 AM
the supported device list dun have WS-SVC-ASA-SM1 blade module for Cat6807.
anyone can confirm this is not supported?
05-06-2015 06:29 AM
chan zuan hua,
The PI 2.2 supported device list includes "Cisco Catalyst 6500 Series ASA Services Module OID:1.3.6.1.4.1.9.1.1277". That's the same module that's used in the 6807.
05-07-2015 02:47 AM
THanks I manage to use SNMPv3 to monitor, somehow when combine, SNMPv1 cannot run.
03-22-2016 02:49 AM
Hello!
How did you configured it ?
I want to integrate an ASA 5520 with prime 2.2 (SNMP v3). The prime gives me the error:
Collection Status : SNMP Failure: Failed to create v3 USM User.
Please help
Thank you
03-22-2016 09:05 AM
What version of ASA software do you have?
PI requires ASA 9.1(2) or later to resolve an SNMP incompatibility issue.
03-23-2016 12:02 AM
We use the ASA-s in multiple context.
My version is 8.2(5). Is there another way to integrate the ASA in prime with SNMP v3? I was not able to configure SNMP v2.c because I don't have Read and Write Community passwords to configure in CLI.
03-23-2016 06:06 AM
The issue has nothing to do with SNMP version.
There is an incompatibility with the older versions of ASA software being unable to interpret and respond to the SNMP queries as sent from Prime Infrastructure.
The requirement is documented in the PI 2.2 Supported Devices matrix:
http://www.cisco.com/c/en/us/support/cloud-systems-management/prime-infrastructure/products-device-support-tables-list.html
03-25-2016 12:34 AM
In this case we will need to upgrade the ASA IOS.
Thank you very much
10-03-2018 01:48 AM
Hi All ,
I encountered the same error once which was really annoying.
However this is what I realised or how I got the solution .
For example
snmp-server user prime TEST v3 auth md5 12345 priv aes 128 12345
snmp-server user prime02 TEST v3 auth md5 12345 priv aes 128 12345
Thank you.
Hope this helps someone in case you run into such a problem in the future.
02-08-2016 06:17 AM
Sorry to interfere in a thread initiated by someone . I have asa 5585 and pi2.2.
Unfortunately i cant even add the asa to the PI?(with only snmp parameters )
Please help
02-08-2016 06:23 AM
You need to provide PI both SNMP RO and cli login credentials. With those, I have successfully added an ASA 5585 to PI 2.x.
Also, PI 3.x allows for collection of interface performance statistics from ASAs.
02-14-2016 11:50 PM
Hi ,
i am getting the error message below
verification of one or more of the following fields failed
SNMP read community . Please fix this and retry
I made sure snmp community string are correct .
snmp-server host Inside 192.168.100.100 trap community ***** version 2c
no snmp-server location
no snmp-server contact
snmp-server enable traps syslog
snmp-server enable traps cpu threshold rising
Please help
