Monitoring interface traffic in Prime infrastructure 3.5
Netzwerker
We have Cisco Prime Infrastructure 3.5, T tried to add a tab under Monitor / Monitoring Tools / Performance Graphs to monitor utilization in RX and TX of a physical interface but it give me the error "No Metrics available for this Interface".
What can I do?
Note: this error is shown for the majority not for all interfaces and Netflow is not configured.
marce1000
 - You may want to remove and re-add the particular device in Prime but use the button Verify Credentials first before the final add , also note that your Prime version is getting rather old, using recent version is advised , in that context also take a look at https://www.cisco.com/c/dam/en/us/td/docs/net_mgmt/prime/infrastructure/3-5/supported/devices/PI35-Supported-Device-List.xlsx   , devices may get upgraded and become incompatible with older Prime version(s) -> Lookup your device and  check S/W column , make sure PI3.5 can still handle your device.
 M.
Hi marce1000,
Thank for your reply!
For the same device, I cant see interface performance (TX/RX) for some interfaces but not available for all interfaces!
I want to know if Netflow must be configured or SNMP is sufficient for this use case?
 - Prime does not need Netflow for interface monitoring , snmp  only. My arguments may still apply , if for instance these interfaces relate to new modules , and or are related to more recent hardware (for instance) or simply different types then  the ones you can monitor.
 M.
