11-06-2011 07:49 PM
I'm running 12.2(33)SXJ1 on a 6500 with several IPv6 BGP peers. Is there any way to monitor the BGP status of IPv6 peers? I've been through the BGP4 mib and cant seem find a way to check the status of IPv6 peers.
Does anyone have any thoughts on this?
11-15-2011 09:41 AM
Here is the Cisco Feature Navigator link to the BGP4 MIB. Here is the MIB. And here is the OID page as well. The CISCO-BGP4-MIB does support IPv6.
Take a look at:
.1.3.6.1.4.1.9.9.187.1.2.1
cbgpPeerTable OBJECT-TYPE
-- FROM CISCO-BGP4-MIB
DESCRIPTION "BGP peer table. This table contains,
one entry per BGP peer, information about
the connections with BGP peers."
However I did find CSCso90107 which you may be running into.
Thanks.
11-25-2011 12:10 PM
That bug does not apply to me.
I dont see any IPv6 address when I query .1.3.6.1.4.1.9.9.187.1.2.1.
snmpwalk -c sdasdadad -v2c XXXX.sctn01 .1.3.6.1.4.1.9.9.187.1.2.1
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.1 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.2 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.15 = STRING: "hold time expired"
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.17 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.20 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.21 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.24 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.26 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.27 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.28 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.31 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.34 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.37 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.39 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.40 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.41 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.45 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.47 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.49 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.51 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.57 = STRING: "hold time expired"
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.58 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.59 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.61 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.62 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.64 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.65 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.86 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.87 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.95 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.96 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.100 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.103 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.104 = STRING: "update malformed"
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.107 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.108 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.118 = STRING: "hold time expired"
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.121 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.126 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.127 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.128 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.130 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.132 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.146 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.157 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.162 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.167 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.181 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.182 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.188 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.191 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.197 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.199 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.201 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.204 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.213 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.217 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.218 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.219 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.222 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.223 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.7.XXX.XX.160.225 = ""
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.1 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.2 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.15 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.17 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.20 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.21 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.24 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.26 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.27 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.28 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.31 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.34 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.37 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.39 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.40 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.41 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.45 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.47 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.49 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.51 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.57 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.58 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.59 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.61 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.62 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.64 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.65 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.86 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.87 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.95 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.96 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.100 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.103 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.104 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.107 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.108 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.118 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.121 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.126 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.127 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.128 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.130 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.132 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.146 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.157 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.162 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.167 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.181 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.182 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.188 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.191 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.197 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.199 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.201 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.204 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.211 = INTEGER: 6
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.212 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.213 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.217 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.218 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.219 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.222 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.223 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.187.1.2.1.1.8.XXX.XX.160.225 = INTEGER: 5 snmpwalk -c sdasdadad -v2c XXXX.sctn01 .1.3.6.1.4.1.9.9.187.1.2.1
05-31-2012 02:21 PM
Hi Jimmy,
I see it's a while since you posted this question, and since then you may have found an answer to your question via other means. The answer to your question , is the CISCO-BGP4-MIB and the cbgpPeer2Table, which contains information about BGP Peers. Please refer to http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?local=en&translate=Translate&objectInput=1.3.6.1.4.1.9.9.187.1.2.5.1#oidContent
cbgpPeer2Table was added to the CISCO-BGP4-MIB definition in Sept 2010, to provide support for IPv6. Depending on the version of code you are running, support for this version of the MIB may not be implemented in your code.
Derek Clothier
02-04-2013 10:39 AM
Hi Derek,
have you any suggestion for ASR1k? We are running IOS-XE 3.4.4S - 15.1(3)S4 but there is no entry in any cbgpPeer2* table.There are cbgpPeer tables only containing just IPv4 information. Thank you.
Michal
