Multiple IPSEC tunnels from ASA using loopback.
ds00476784@techmahindra.com
Frequent Visitor
Frequent Visitor
We have Zscaler proxy in our environment. And we have created IPSEC tunnel between on prim ASA to Zscaler cloud.
Firmware Ver 9.12
Zscaler have limited B/w for each IPSEC tunnel to 200 Mb. Currently is tunnel is sourced from outside interface ip. Now we need to create more IPSEC tunnels to over come B/w limit.
As per Zscaler if multiple tunnels have same source IP then it will be considered as 1 and accumulate b/w will remain 200 Mb.
We thought of creating loop back ips with static public Ips and use them as tunnel source. Now ASA dont support loopback so need alternative.
Zscaler proxy support VTI ?
if it support then config multi VTI in ASA using same OUT interface.
No it only support Policy based vpn. No route based. VTI interface might not help.
Add a second/third/forth ASA?
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
