n5k and n7k config questions
Nell_Ko
Greetings!
I have few questions regarding n5k and n7k configurations.
First I have 2 sets of n5k and 1 set of n7k and  their os vers are below
model : n5k-c5548
Os : 7.0(8)N1(1)
       5.0(3)N1(1c)
model n7k-c7710
Os : 6.2(16)
Now I have questions about command lines for n5k and n7k
I know that those 4 commands below are from IOS to disable certain services,
but I do not know whether n5k and n7k have those same commands.
If n5k and n7k do have the commands please let me know :(
or
if n5k and n7k not have the commands, then please tell me where I can find the documents about it.
A. no ip http server
B. no ip http secure-server
C. no ip bootp serber
D. no service pad
Nell
Mark Malone
Its different in NX-OS first you turn on a feature to get it , so http its just no enabled by default unless you enable it first though feature section like below , the command guide online for each release software guide contains all commands and syntax , where you download the images
(config)# feature h?
hsrp Enable/Disable Hot Standby Router Protocol (HSRP)
http-server Enable/Disable http-server
No boot its not supported only DHCP or service pad , service pad is x25 legacy
Mark Malone
i did typed "feature ?" on n5k
but i dont see http-server.
Does this mean that Cisco has disabled and removed the function?
no thats off my 5ks its there on this image anyway , not in my 7ks though
sh ver | i n5000
kickstart image file is: bootflash:///n5000-uk9-kickstart.7.3.3.N1.1.bin
system image file is: bootflash:///n5000-uk9.7.3.3.N1.1.bin
Thanks!
I wasn't so familiar with nexus series :(
I realized that i have to check the os version of the nexus before checking certain command.
