N7706,N5672,N3172 supported on LMS 4.2.5 or PI ?
Hung Tsung Chen
Does PI or LMS 4.2.5 support N7706,N5672 and N3172 ?
I couldn't find these three models on the supported device list.
Vinod Arya
Its better you share the system ID for these devices which makes much easier to find support.
Do a snmp poll for these devices for object sysObjectID (1.3.6.1.2.1.1.2and share result. We can search with this info much faster.
-Thanks
Vinod
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Hi Vinod:
The switches(Nexus 7706,Nexus 5672,Nexus 3172) are still on the road to the customer.
We also plan to deploy PI or LMS to mange and monitor these switches.
But I can't get information when these switches will be supported on PI or LMS.
Thanks.
As each platform has a lot of different models and part number, we cannot be specific unless sure about a exact model number or sysObjectID of the device.
Anyone in general would end up checking the supported device table/list for specific software version :
Supported devices for LMS 4.2
Supported devices for Prime Infrastructure 2.1
-Thanks
Vinod
Hi Vinod,
The exact models are N77-C7706,N3K-C3172TQ-10GT,N3K-C3172PQ-10GE and N5K-C5672UP.
I checked the suuported device table,they are not in the list.
Do you know which version of PI and LMS will support these models ?
Thanks.
