NAM 1 Configuration
mrcomm2000
Dears
How can i monitor the WAN traffic (POS) with the NAM. I have done all the required configuration in the manual,
Cat6500# configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
Cat6509(config)# access-list 100 permit ip any any
Cat6509(config)# vlan access-map wan 100
Cat6509(config-access-map)# match ip address 100
Cat6509(config-access-map)# action forward capture
Cat6509(config-access-map)# exit
Cat6509(config)# vlan filter wan interface ATM6/0/0.1
Cat6509(config)# analysis module 3 data-port 1 capture allowed-vlan 1-4094
What is the next step from the traffic analyzer?
BR
rmushtaq
Level 8
Level 8
You need to SPAN the source, turn on the collections and then should be able to monitor it in the NAM GUI
