NAM Upgrade Problem
m.samouka
While I was upgrading NAM 2 from ver 3.6 to 4.1 I found that the connection is (Flapping) after the upgrade, then I found the following error on the core. (The NAM module is restarting)
000947: 12w1d: %SNMP-5-MODULETRAP: Module 2 [Down] Trap
000948: 12w1d: %OIR-SP-3-PWRCYCLE: Card in module 2, is being power-cycled 'off (Module not responding to Keep Alive polling)'
000949: 12w1d: %C6KPWR-SP-4-DISABLED: power to module in slot 2 set off (Module not responding to Keep Alive polling)
After checking the error meaning, I have found that the workaround is to restart the module many times!!
But the problem never solved, the problem only is resolved if I restarted the NAM in the (cf:1) mode, otherwise the module keeps restarting.
The following are the output of the show ver:
root@NAM2.Xceed# show ver
NAM application image version: 3.6(1a)
Maintenance image version: 2.1(3)
NAM Daughter Card Micro code version: 1.34.1.28 (NAM)
BIOS Version: 4.0-Rel 6.0.4
Installed patches:
No patches are installed on this system.
And the Version I'm upgrading to is (the same as NAM1):
upgrade ftp://172.17.0.10/c6svc-nam.3-6-1a.bin.gz
Could anyone help to resolve this problem?
5 Replies 5
Lucien Avramov
Level 11
Level 11
Can you please post a show module from the switch and a show version from the switch?
Can you also run the following memory test from the switch:
hw-module module 2 reset mem-test-full
The output of the show module on the switch:
#sh module
Mod Ports Card Type Model Serial No.
2 8 Network Analysis Module WS-SVC-NAM-2 SAD070802VL
Mod MAC addresses Hw Fw Sw Status
2 0002.7ee5.048c to 0002.7ee5.0493 1.0 7.2(1) 3.6(1a) Ok
Mod Online Diag Status
2 Pass
The output of the show Version on the switch:
#sh ver
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVENTERPRISEK9_WAN-M), Version 12.2(33)SXI1, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Sat 28-Mar-09 10:30 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX5, RELEASE SOFTWARE (fc1)
XCC_CAI01_CORE02 uptime is 13 weeks, 2 days, 13 hours, 20 minutes
Uptime for this control processor is 13 weeks, 2 days, 13 hours, 37 minutes
Time since XCC_CAI01_CORE02 switched to active is 13 weeks, 2 days, 13 hours, 36 minutes
System returned to ROM by power cycle at 12:58:02 UTC Tue Jun 16 2009 (SP by power on)
System restarted at 21:57:04 CLT Mon Jun 22 2009
System image file is "sup-bootdisk:s72033-adventerprisek9_wan-mz.122-33.SXI1.bin"
Last reload reason: Unknown reason
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6513 (R7000) processor (revision 2.0) with 983008K/65536K bytes of memory.
Processor board ID SAL1306J6JY
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
1 SIP-200 controller (8 E1).
11 Virtual Ethernet interfaces
212 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
12 Serial interfaces
8 Channelized E1 ports
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Just a small update, the version I'm upgrading to is: upgrade ftp://172.17.0.10/c6svc-nam.4-1-1.bin.gz
Any ideas?
branfarm1
Level 8
Level 8
Hi there,
Were you ever able to find a resolution for this issue?  I'm having the exact problem with my NAM-2 module and I can't figure out any steps.  Is this a bug in 4.1?
Brandon
i have paused the upgrade till i find an answer, but i will try again in the coming day. i still didn't find an answer for the situation.
i'll inform u if i succeeded in my upgrade...
