I've been having an issue in Packet tracer while trying to set up NAT on the ASA 5505. When sending a ping the outside router from an inside client, the address is not translated at the ASA, and as such the outgoing source remains the clients private IP. I am very new to networking, however from what I have read this should be working with the current config. Strangely, I can get NAT to work by changing the network object for the internal subnet to static NAT, then changing it back to dynamic interface, though this does not survive a reboot and the problem persists. This could be a simple issue or a lack in my knowledge, but I have been stuck trying to fix this for a few days now and haven't been able to make any progress. Any help would be greatly appreciated.
Config for firewall
ciscoasa(config-network-object)#sh run
: Saved
ASA Version 8.4(2)
hostname ciscoasa
names
interface Ethernet0/0
interface Ethernet0/1
switchport access vlan 2
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 100
ip address 200.201.202.1 255.255.255.0
object network inside_to_outside
subnet 192.168.10.0 255.255.255.0
nat (inside,outside) dynamic interface
route outside 0.0.0.0 0.0.0.0 200.201.202.2 1
route inside 192.168.10.0 255.255.255.0 192.168.1.2 1
telnet timeout 5
ssh timeout 5
dhcpd auto_config outside
dhcpd address 192.168.1.5-192.168.1.36 inside
dhcpd enable inside
Multilayer switch config
Switch>en
Switch#sh run
Building configuration...
Current configuration : 1457 bytes
version 12.2(37)SE1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Switch
ip routing
spanning-tree mode pvst
interface FastEthernet0/1
interface FastEthernet0/2
switchport mode trunk
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
ip address 192.168.1.2 255.255.255.0
interface Vlan10
mac-address 000c.8592.6301
ip address 192.168.10.1 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip route 192.168.10.0 255.255.255.0 192.168.1.1
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
