NAT problem - VLAN.dat can't be fetched due to NAT'd IP address of PI
gabor.rozsa
My PI2.2 is behind a Firewall where my local IP address (192.168.1.2) is translated to an outside global IP address (12x.xx.xx.xx):
+------+ 192.168.1.2    | F | 12x.xx.xx.xx     +--------+      +----------+
|PI 2.2+----------------+ W +------------------+ cloud  +------+  device  |
My problem is that I can see that PI can't download the vlan.dat file from the remote switch via TFTP as it tries with the pre-NAT'd IP as the destination server not the NAT'd address. The following output is an assembled wireshark Telnet session when PI tries to download the vlan.dat file:
switch#terminal length 0
switch#terminal width 0
switch#
switch#
switch#show privilege
Current privilege level is 15
switch#
switch#copy flash:vlan.dat tftp:
Address or name of remote host []? 192.168.1.2
Destination filename [vlan.dat]? 20150618231154954-12x
.xx.xx.xx.cfg
%Error opening tftp://192.168.1.2/20150618231154954-12x
.xx.xx.xx.cfg (Timed out)
switch#
switch#
switch#
I'm not suprised it times out as the remote host address should be 12x.xx.xx.xx not 192.168.1.2.
Is there a way to force Prime Infrastructure to use the NAT'd address in such cases? I was told in LMS there is an option but I couldn't find any in PI.
Gabor
rosaho
Level 3
Level 3
This discussion has been modified to comply to the CSC terms of use conditions.
gabor.rozsa
Update
This problem is present from earlier versions of PI as it was reported 13 months ago in this support forum discussion:
https://supportforums.cisco.com/discussion/12180876/cisco-prime-infrastructure-and-vlan-fetch
Unfortunately the issues is still in PI2.2 and this was confirmed by TAC engineer. Two options are:
1. Make the actual IP address of PI routable from the device.
2. Open PER request to add this in coming PI versions .
I can accept this however I think it would be great to read it somewhere in the Admin and/or design guide of PI that you are not supposed to use PI behind any network device NATing PI's IP address.
