NAT same IP
I have a "simple" problem that is killing my brain..
The problem..., I have a lab with many different brands and models of network equipment, mainly low/mid range routers.
What I'm trying to do is get a way to access all those equipments from the internet, or behind a single IP.
But there are some problems...
Those equipments must be in factory configuration state, so I will have many equipments with the same IP
Equipments will have no gateway...
What I made so far...
I have all those equipments connected to a switch, all landing in a different VLAN
This switch connects in a trunk interface to my internet router
My Internet router as one vlan interface for each vlan and each vlan interface as it's own vrf
I thought in using the wan port for choosing the equipment I want to connect to
For example:
Equipment 1 - IP 192.168.0.1, has telnet access, connect to the switch in vlan 100
Equipment 2 - IP 192.168.0.1, has telnet access, connect to the switch in vlan 200
The internet router
WAN IP is 100.0.0.1
Interface vlan 100, in VRF v100, with IP 192.168.0.200 255.255.255.0
Interface vlan 200, in VRF v200, with IP 192.168.0.200 255.255.255.0
My idea is to user wan port's for choosing what equipment I will connect to
For example telneting to 100.0.0.1 in port 10023, I would access to Equipment 1, or telneting to 100.0.0.1 in port 20023, I would access to Equipment 2
My main difficulty is to pass traffic from my WAN into the correct vrf depending on the port I connect
Other difficulty is when the traffic reaches the Equipment 1, it must have a source IP in the same network of that equipment, because the equipment's will not have gateways...
Any suggestion?
Oleg Volkov
Hello!
We may select other way, place all devices in single VLAN, then try to access to default IP from your gateway (Cisco for example), you will established telnet to some devices, which of devices You can detect by Mac or any inventory data. After this , change Ip and add gateway. And repeat it for next device.
If you have any ASA devices, You can simply configure source nat and multi context , and realize. Your idea.
Helping seriously ill children, all together. All information about this, is posted on my blog
Thanks. Oleg
The first solution is not really what I pretend...
I want all devices to be available all the time. If any one does changes to those devices and what to revert it, it would take a simple factory reset and that device would become available immediately.
You are suggesting an ASA, this scenario is not doable with a cisco router using VRF's?
Nat from global to vrf do with "vrf <VRFNAME>
I try to simulate Your case in my lab and answer You
