NCS - Reducing usage on /dev/mapper/smosvg-optvol
ThomasPemberton
Recently upgraded our install from 1.0.2.29 to 1.1.0.58 and started recieving alerts from NCS about usage on this disk space being over 50% used.  Didn't change any settings/retention periods during the upgrade so not sure why this alert started coming up.  Would anyone know what this disk area is used for and how to reduce useage?
~Tom
Eric Lindsey
We did the same thing today.  We are now getting the alerts that we are above the 50% threshold.  Did you ever get an answer for this question?
I opened a TAC case and talked to Cisco.  They basically said it is a new alert that was added in that version of NCS and that my disk usage was normal.  No way to disable the alert except to aknowledge it every time it comes up...
