Need help for EEM applet to get working
SanjayRaut19786
event manager applet SHOW_INT_LINK
event cli pattern "(sh|sho|show)\s+(int|inte|inter|interf|interfa|interfac|interface)\s+(link)" enter
action 001.1 cli command "enable"
action 001.2 puts "\n\nShow Interface Link (List shows ONLY notconnect ports)\n------------------------------------------------------"
action 001.3 cli command "show int status | i notconnect"
action 002.1 foreach _line "$_cli_result" "\n"
action 002.2 regexp "^([A-Z][a-z][0-9][^[:space:]]+)" "$_line" match _intf
action 002.3 if $_regexp_result eq "1"
action 003.1 cli command "show interface $_intf"
action 004.1 foreach _iline "$_cli_result" "\n"
action 004.2 regexp "^(.*Last input.*)\r$" "$_iline" match _lastup
action 004.3 if $_regexp_result eq "1"
action 004.4 puts "$_intf -$_lastup"
action 004.5 end
action 099.1 end
action 099.2 end
action 099.3 end
Above script is working well and listing the ports which are 'not connect' and Last Input never. However how it get it disabled via a script by adding CLI commands in the applet.
Can anyone suggest please how to get the ports disabled ?
Sanjay
0 Replies 0
