01-07-2014 06:16 PM
Hi :
I need the Cisco ASA5520 SYS OID for the LLDP protocol so that I can create the network connection between Cisco ASA5520 and the 3rd party networking device in this 3rd party network management management system.
Can anyone help on this?
I tried to search the web and got some LLDP MIB files but they all cannot solve the problem. What I think and I need to have now is the SYS OID number for this Cisco ASA5520.
I know that the SYS OID for ASA5520 is 1.3.6.1.4.1.9.1.670. Now I need is the SYS OID for its LLDP protocol. Can someone help on this?
Many thanks!
tangsuan
01-07-2014 08:05 PM
Hi Tang,
Not sure what exactly you are looking for .
can you share the equivalent CLI command
Thanks-
Afroz
01-07-2014 09:33 PM
Hi Afroj Ahmad:
I think it is not due with command line. It is the lack of OID information for Cisco ASA5520 to be able discovered by 3rd party Network Management System.
If I am not wrong, the ASA5520 should have been configured correctly for providing SNMP to the 3rd party network management system (NMS) and as such, the NMS is then able to capture the the SYS OID for ASA5520 is 1.3.6.1.4.1.9.1.670 from the ASA5520.
The SNMP configuration is as below:
snmp-server host inside 172.16.0.82 community public version 2c
snmp-server host inside 172.16.8.50 community public version 2c
no snmp-server location
no snmp-server contact
snmp-server community public
snmp-server enable traps snmp authentication linkup linkdown coldstart
snmp-server enable traps syslog
snmp-server enable traps ipsec start stop
snmp-server enable traps entity config-change fru-insert fru-remove
snmp-server enable traps remote-access session-threshold-exceeded
The 3rd party NMS can capture the product OID from ASA5520 after given the ASA IP address to the NMS. It is the LLDP OID that is not included in the product OID to cause the 3rd NMS cannot link up the LAN connction between the ASA and the 3rd party switch. There is no LLDP configuration in ASA command. I believe the LLDP should be provide externally either by key in manually or upload the MIB file to the 3rd party NMS. I have tried also uploading few MIB files but all not succesfully done.
I think the direct method is just key in the LLDP OID inside the 3rd party NMS system so that the 3rd NMS can embed the LLDP information into its operation kernel then the NMS can link up the LAN connection between the Cisco ASA and its switch.
Many thanks!
tangsuan
01-07-2014 11:11 PM
HI tangsuan,
Thanks for the details explaination.
LLDP support via SNMP is very minimal or may be not.
Also ASA does not support LLDP-MIB
below is the support MIBS for LLDP:
ftp://ftp.cisco.com/pub/mibs/supportlists/asa/asa-supportlist.html
check this OLD post as well:
https://supportforums.cisco.com/thread/171302
Thanks-
Afroz
[Do rate the useful post]
01-08-2014 10:03 PM
Hi AFROJ AHMAD:
Thanks to your reply!
I have tried to use the downloaded LLDP MIB file provided from your information by in-corporating it into the 3rd party Network Management System, the Cisco ASA5520 still cannot be automatically linked up with the 3rd party switch.
I would say that the LLDP MIB file downloaded is not provided the proper SNMP LLDP information.
As such, this problem is yet to resolve. I doubt there is a way to resolve.
Is Cisco ASA5500 series development team know something about this and can give some solution or advise on this?
Many thanks!
tangsuan
01-08-2014 10:42 PM
Hi tangsuan,
The problem is with the SUPPORT of the LLDP with ASA .
If it is really Imp and a area of concern , I would suggest to open a case so that TAC can contact the Development team to know the status of thsi MIB support.
Thanks-
Afroz
[Do rate the post ,if you find it helpful]
01-12-2014 05:27 PM
The Cisco ASA software does not support either LLDP or Cisco's CDP. So no matter how you configure or query it, no layer 2 neighbor discovery protocol information will result.
01-13-2014 09:38 PM
Hi Marvin:
Thanks a lot on your reply!
If in this case of without LLDP and CDP, even with Cisco LMS, we also cannot see the network link between a ASA firewall and a network device like Cisco Switches or Router, right? Please help to confirm.
Many thanks!
Bset regards,
tangsuan
01-14-2014 01:41 AM
You're welcome.
You cannot 'see' the link in an LMS topology map - an ASA will always be put into the "unconnected devices" view. You can monitor the link status and performance with the Fault etc. tools in LMS.
01-14-2014 02:32 AM
Hi Marvin:
Thanks to your reply. Somehow quite disappointed about the ASA feature that it cannot be seen at Network Management System.
best regards,
tangsuan
