need to idendify User's IP addresses CNR, LDAP, ACS
htsiartas
client is a large university with multible campuses and thousands of users.
client needs as way to link usernames to IP addresses,
for example if there is a network missuse or signature attack, triggered in NIDS, the administrators would like to be able to link an IP addresses to a User.
CNR is used for both DHCP and DNS, and there is an LDAP (v3 Sun one) deployment storing all users info and credentials. Client is looking ways to integrate the two to provide a link between IP addresses and Usernames.
Are there any tools that can make the integration of LDAP and DHCP?
client is looking in using 802.1x with ACS and external LDAP integration as well to authenticate users in LDAP prior to receiving an IP address
smalkeric
Level 6
Level 6
You may find this document useful which explains the configuration of the Cisco Network Registrar for DHCP, DNS servers.
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/ciscoasu/nr/nr3-5/getting/gs02.htm
Hope this helps.
