10-29-2021 01:01 PM
We recently set up a new SF250-48HP 48-Port 10/100 PoE Smart Switch. I went to add an Cisco IP phone to the network and it would not connect. I get an IP address but the DNS information does not come through. I need to know how to set the VoIP settings on this switch. Thanks and advance.
10-29-2021 01:09 PM
follow below guide :
10-29-2021 01:34 PM
10-29-2021 03:49 PM
If you get a chance logging to switch cli, and post-show run
05-12-2022 05:14 AM
Hello BB,
Thank you for your response. I got pulled off to another project and this took a while to get back to this. I tried connecting to the switch with Putty to open a CLi, but the switch refused the connection. I am very new to this switch so I may have a setting wrong in the switch. I am connected and logged in through the web interface. Any guidance would be greatly appreciated.
Michael
05-12-2022 03:23 PM
means you are not able to Login ? do you see login prompt on the console ?
10-29-2021 02:00 PM
what does the DHCP pool for your voice Vlan look like ?
05-12-2022 05:16 AM
Hello
Thank you for your response. I got pulled off to another project and this took a while to get back to this. The DCHP pool is
Range: 192.168.40.103 - 192.168.40.254 |
Michael
