NETCONF RPC error
joeldoetsch
Frequent Visitor
Frequent Visitor
Hello, I'm running IOS XE 16.9.4 on a Catalyst 9300.  I'm trying to build a few NETCONF scripts to get a better understanding of it.  I've cobbled together a script from various examples just to test out pulling interface information, but I've hit a wall.  I'm getting an RPC error that I can't find a solution for, and was hoping someone could point me in the right direction.  Unfortunately, I have almost no experience with this, so I'm kind of treading water.
Error message:
Traceback (most recent call last):
File "C:\automate\Network\netconftest.py", line 35, in <module>
state_data = m.get(filter=interface_filter).xml
File "C:\automate\Network\network_automation\lib\site-packages\ncclient\manager.py", line 246, in execute
return cls(self._session,
File "C:\automate\Network\network_automation\lib\site-packages\ncclient\operations\retrieve.py", line 91, in request
return self._request(node)
File "C:\automate\Network\network_automation\lib\site-packages\ncclient\operations\rpc.py", line 375, in _request
raise self._reply.error
ncclient.operations.rpc.RPCError: {'type': 'protocol', 'tag': 'access-denied', 'app_tag': None, 'severity': 'error', 'info': None, 'path': None, 'message': None}
Here's the script
from ncclient import manager
from pprint import pprint
import xmltodict
import xml.dom.minidom
router = {
    'ip': '<redacted>',
    'port': '830',
    'username': '<redacted>',
    'password': '<redacted>'
m = manager.connect(host=router['ip'], port=router['port'], username=router['username'], password=router['password'], device_params={'name':'iosxe'}, hostkey_verify=False)
print(m.connected)
my_ints = ["1/0/15","2/0/23"]
for x in my_ints:
    interface_filter = '''
      <filter>
          <native xmlns="http://cisco.com/ns/yang/Cisco-IOS-XE-native">
              <interface>
                  <GigabitEthernet>
                      <name>'''+str(x)+'''</name>
                  </GigabitEthernet>
              </interface>
          </native>
      </filter>
    print (interface_filter)
    print(xml.dom.minidom.parseString(state_data).toprettyxml())
#running_config = m.get_config('running', interface_filter).xml
#print(xml.dom.minidom.parseString(running_config).toprettyxml())
m.close_session()
Thanks in advance
joeldoetsch
Frequent Visitor
Frequent Visitor
I finally figured it out.  It was silly.  It's because the user I was logging in with didn't have a high enough privilege level
pieterh
I'm not a scripting guru but try changing the section
<interface>
  <GigabitEthernet>
  </GigabitEthernet>
</interface>
to
<interfaces>
  <interface>
  </interface>
</interfaces>
source: slides-edu-network-configuration-with-netconf-00.pdf (ietf.org)
That was a good thought, but unfortunately, I still received the same error message.  Thanks for the reply, though!
joeldoetsch
Frequent Visitor
Frequent Visitor
