NetConfig
afortuin1
I used Netconfig to deploy ACL's on routers. It work fine when I did up to 30 routers at one time. When I did it with 68 routers it gave me major problems. It only deployed halve of the ACL's on some of the routers bringing those links to a halt. Is there a limit of how many routers you can deploy at one time?
n.bowbridge
Are you deploying the job in Parallel or Sequential mode? If parellel try seqential, its helped me before.
I did it in Sequential mode. The wan links is to slow here to do it in parallel.
