01-23-2020 04:58 AM
Hi all,
For a customer I'm trying to implement Netflow using:
Flexible Netflow Configuration Guide, Cisco IOS Release 15M&T
The configuration guide gives the literal commands:
Device(config)# interface GigabitEthernet 0/0/0
Device(config-if)# ip flow monitor FLOW-MONITOR-1 input
On my C2911 is cannot enter this command and i cannot figure out why not..
This is what I get and I need input on the interface:
8015223_T027(config-if)#flow mo
8015223_T027(config-if)#flow monitor ?
egress Egress flow sampler
8015223_T027(config-if)#flow monitor MONTOR-1?
% Unrecognized command
I have tested this with 152.-4M6a, 153-3M8a and 157-3M5 firmware versions. Perhaps I need an additional package to activate? All documents I have read do not mention this...
Does this sound familiar to anyone? What did you do to fix the problem?
Any suggestions are welcome! Thanks in advance!
Marnix
01-23-2020 05:05 AM
Can you post show version from the device you having this issue ?
01-23-2020 05:16 AM
Ofcourse I used:
8015223_T027(config-if)#ip flow
8015223_T027(config-if)#ip flow ?
01-23-2020 05:39 AM
Can you post below outout from the device :
show version
show license
01-23-2020 06:16 AM
show ver:
#sh ver
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.2(4)M6a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Tue 15-Apr-14 09:45 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
8015223_T027 uptime is 21 weeks, 3 days, 18 hours, 37 minutes
System image file is "flash0:c2900-universalk9-mz.SPA.152-4.M6a.bin"
Last reload type: Normal Reload
Last reload reason: power-on
Cisco CISCO2911/K9 (revision 1.0) with 483328K/40960K bytes of memory.
Processor board ID FCZ180570XR
7 Gigabit Ethernet interfaces
1 terminal line
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*0 CISCO2911/K9
Technology Package License Information for Module:'c2900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security securityk9 RightToUse securityk9
uc None None None
data None None None
Show license:
7#show license
Index 1 Feature: ipbasek9
Period left: Life time
License Type: Permanent
License State: Active, In Use
License Count: Non-Counted
License Priority: Medium
Index 2 Feature: securityk9
License Type: RightToUse
License Priority: Low
Index 3 Feature: uck9
Period left: Not Activated
Period Used: 0 minute 0 second
License Type: EvalRightToUse
License State: Not in Use, EULA not accepted
License Priority: None
Index 4 Feature: datak9
Index 5 Feature: gatekeeper
Index 6 Feature: SSL_VPN
License Count: 0/0 (In-use/Violation)
Index 7 Feature: ios-ips-update
Index 8 Feature: SNASw
Index 9 Feature: hseck9
Index 10 Feature: cme-srst
Index 11 Feature: WAAS_Express
Index 12 Feature: UCVideo
Thank you!
01-23-2020 06:46 AM
Can you also post
#sh license feature
just want to confirm the license.
01-24-2020 12:20 AM
#sh license feature
Feature name Enforcement Evaluation Subscription Enabled RightToUse
ipbasek9 no no no yes no
securityk9 yes yes no yes yes
uck9 yes yes no no yes
datak9 yes yes no no yes
gatekeeper yes yes no no yes
SSL_VPN yes yes no no yes
ios-ips-update yes yes yes no yes
SNASw yes yes no no yes
hseck9 yes no no no no
cme-srst yes yes no no yes
WAAS_Express yes yes no no yes
UCVideo yes yes no no yes
So is there something I could have looked for? So I would not have to bother you fine people?
Thanks again for looking!
