Netflow is not working on 3560 after the IOS upgrade to 15.0(2)SE8
Hi ,
I am facing one issue where Netflow is not working on 3560 after the IOS upgrade to 15.0(2)SE8.
All the configureation is fine .Let me know if you have any solution for the same
ANU M
The issue got resolved as the when we are doing the IOS upgrade ,we needs to upgrade the image file for the service module and we can run below comments,able to see that image file ver miss match.
SW1#sh switch service-modules
Switch/Stack supports service module CPU version: 03.00.80
                          Temperature                     CPU
Switch#  H/W Status       (CPU/FPGA)      CPU Link      Version
1       OK               75C/73C         ver-mismatch  03.00.76
We need to upgarde the image for the service module also.Procedure mentioned below
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/15-0_1_se/release/notes/OL25302.html#wp1048167
Recognize Your Peers
