03-02-2020 04:56 PM
I have a 3750G and 3750X which were both running Netflow and exporting to PRTG fine. I recently powered them down and changed some interface configurations around, renamed both switches (basically I'm using the 3750x as a core switch now instead of an access switch). Everything works fine, except netflow doesn't seem to export at all now. I made no changes to the netflow configuration at all. I've turned terminal monitor on and run "debug ip flow", "debug ip flow cache" and "debug ip flow non-forwarded" on both switches and I get nothing in the CLI. Here's some example output from one of the switches:
#do sh ip flow export Flow export v1 is enabled for main cache Export source and destination details : VRF ID : Default Source(1) 10.8.255.2 (Loopback1) Destination(1) 10.5.7.172 (9997) Version 1 flow records 0 flows exported in 0 udp datagrams 0 flows failed due to lack of export packet 0 export packets were sent up to process level #do sh flow export stat Flow Exporter NetFlow-To-PRTG: Packet send statistics (last cleared 00:46:58 ago): Successfully sent: 0 (0 bytes) Client send statistics: Client: Flow Monitor NetFlow-To-PRTG Records added: 0 Bytes added: 0
#do sh run | s flow
flow record NetFlow-To-PRTG
match ipv4 tos
match ipv4 protocol
match ipv4 source address
match ipv4 destination address
match transport source-port
match transport destination-port
match transport tcp source-port
match transport tcp destination-port
match transport tcp flags
flow exporter NetFlow-To-PRTG
destination 10.5.7.172
source Port-channel1
transport udp 9997
flow monitor NetFlow-To-PRTG
cache timeout active 5
ip flow-export source Loopback1
ip flow-export destination 10.5.7.172 9997
Again, I have not changed any of the netflow config, outside of changing the source interfaces a bit just to see if I could get it to work. I know it's not an IOS version issue because it was running fine before. I tried running "clear ip cef * prefix" but that didn't seem to help either.
I'm kind of at a loss since I didn't touch any of the netflow config when I reconfigured the switches to swap the core and the access switch around. Any help would be greatly appreciated.
03-03-2020 05:07 PM
So I've been reading up. I've tried just about every solution I was able to find from other forums/articles, including changing the export interface to loopback, enabling route-cache, etc. Still don't have a solution though.
03-03-2020 05:46 PM
Full config of one of the switches when everything was working
! ! Last configuration change at 21:23:23 EST Wed Feb 12 2020 by mvd ! NVRAM config last updated at 21:23:26 EST Wed Feb 12 2020 by mvd ! version 15.2 no service pad service timestamps debug datetime msec service timestamps log datetime msec service password-encryption ! hostname Asgard-Switch1 ! boot-start-marker boot-end-marker ! ! vrf definition Mgmt ! address-family ipv4 exit-address-family ! logging buffered 100000 informational ! aaa new-model ! ! aaa authentication login default local aaa authentication dot1x default group radius aaa authorization exec default local none ! ! ! ! ! ! aaa session-id common clock timezone EST -5 0 clock summer-time EDT recurring switch 1 provision ws-c3750x-24 system mtu routing 1500 ! ! ! ! ip routing ! ! ! no ip domain-lookup ip domain-name Bifrost.local vtp domain MikeNet.com vtp mode off ! ! ! ! ! ! flow record NetFlow-To-PRTG match ipv4 tos match ipv4 protocol match ipv4 source address match ipv4 destination address match transport source-port match transport destination-port match transport tcp source-port match transport tcp destination-port match transport tcp flags ! ! flow exporter NetFlow-To-PRTG destination 10.5.7.172 transport udp 9997 ! ! flow monitor NetFlow-To-PRTG exporter NetFlow-To-PRTG cache timeout active 5 record NetFlow-To-PRTG ! ! ! archive path ftp://10.5.7.35/Asgard-Switch-1 time-period 1440 ! ! ! dot1x system-auth-control ! spanning-tree mode rapid-pvst spanning-tree portfast edge default spanning-tree portfast edge bpduguard default spanning-tree extend system-id spanning-tree vlan 5-7,50,297 priority 28672 spanning-tree vlan 19 priority 24576 ! ! ! ! vlan internal allocation policy ascending ! vlan 5 name Management ! vlan 6 name Access ! vlan 7 name Server ! vlan 30 name Dev-Env ! vlan 50 name Asus-Router-Subnet ! vlan 297 name Bornio ! lldp run ! ! ! ! ! ! ! ! ! ! ! ! interface Loopback1 ip address 10.8.255.2 255.255.255.0 ! interface Port-channel1 description Bond-To-Asgard-Core switchport access vlan 297 switchport trunk allowed vlan 6,7,30,50 switchport trunk encapsulation dot1q switchport trunk native vlan 297 switchport mode trunk ! interface Port-channel2 description Bond-To-Asgard-1-NAS switchport access vlan 7 spanning-tree portfast edge ! interface Port-channel3 description Bond-To-Asgard-2-NAS switchport access vlan 7 spanning-tree portfast edge ! interface Port-channel4 description Bond-L3-To-Asgard-Core no switchport ip address 10.5.255.2 255.255.255.0 no ip redirects no ip unreachables no ip proxy-arp ip ospf dead-interval 3 ip ospf hello-interval 1 ! interface FastEthernet0 description Management vrf forwarding Mgmt ip address 10.5.5.2 255.255.255.0 no ip route-cache ! interface GigabitEthernet1/0/1 description Link-L3-To-Asgard-Core no switchport no ip address channel-group 4 mode active ! interface GigabitEthernet1/0/2 description Link-L3-To-Asgard-Core no switchport no ip address channel-group 4 mode active ! interface GigabitEthernet1/0/3 shutdown ! interface GigabitEthernet1/0/4 switchport access vlan 297 shutdown ! interface GigabitEthernet1/0/5 description Mjolnir switchport trunk allowed vlan 6,7,30 switchport trunk encapsulation dot1q switchport trunk native vlan 177 switchport mode trunk ! interface GigabitEthernet1/0/6 description S-NETMON1 switchport access vlan 7 ! interface GigabitEthernet1/0/7 description Thor switchport access vlan 6 spanning-tree portfast edge ! interface GigabitEthernet1/0/8 description ARLO switchport access vlan 50 ! interface GigabitEthernet1/0/9 description S-WINNIX switchport access vlan 6 spanning-tree portfast edge ! interface GigabitEthernet1/0/10 description Aesir switchport access vlan 7 spanning-tree portfast edge ! interface GigabitEthernet1/0/11 switchport access vlan 297 shutdown ! interface GigabitEthernet1/0/12 switchport access vlan 297 shutdown ! interface GigabitEthernet1/0/13 switchport access vlan 297 shutdown ! interface GigabitEthernet1/0/14 switchport access vlan 297 shutdown ! interface GigabitEthernet1/0/15 switchport access vlan 297 shutdown ! interface GigabitEthernet1/0/16 description Link-To-Asgard-1-NAS switchport access vlan 7 spanning-tree portfast edge channel-group 2 mode active ! interface GigabitEthernet1/0/17 description Link-To-Asgard-1-NAS switchport access vlan 7 spanning-tree portfast edge channel-group 2 mode active ! interface GigabitEthernet1/0/18 description Link-To-Asgard-2-NAS switchport access vlan 7 spanning-tree portfast edge channel-group 3 mode active ! interface GigabitEthernet1/0/19 description Link-To-Asgard-2-NAS switchport access vlan 7 spanning-tree portfast edge channel-group 3 mode active ! interface GigabitEthernet1/0/20 description Trunk-To-Asgard-Core switchport access vlan 297 switchport trunk allowed vlan 6,7,30,50 switchport trunk encapsulation dot1q switchport trunk native vlan 297 switchport mode trunk channel-group 1 mode active ! interface GigabitEthernet1/0/21 description Trunk-To-Asgard-Core switchport access vlan 297 switchport trunk allowed vlan 6,7,30,50 switchport trunk encapsulation dot1q switchport trunk native vlan 297 switchport mode trunk channel-group 1 mode active ! interface GigabitEthernet1/0/22 switchport access vlan 297 shutdown ! interface GigabitEthernet1/0/23 switchport access vlan 297 shutdown ! interface GigabitEthernet1/0/24 ! interface GigabitEthernet1/1/1 switchport access vlan 297 shutdown ! interface GigabitEthernet1/1/2 switchport access vlan 297 shutdown ! interface GigabitEthernet1/1/3 switchport access vlan 297 shutdown ! interface GigabitEthernet1/1/4 switchport access vlan 297 shutdown ! interface TenGigabitEthernet1/1/1 switchport access vlan 297 shutdown ! interface TenGigabitEthernet1/1/2 switchport access vlan 297 shutdown ! interface Vlan1 no ip address no ip route-cache shutdown ! interface Vlan5 no ip address ! router ospf 1 router-id 10.8.255.2 passive-interface default no passive-interface Port-channel4 network 10.5.255.2 0.0.0.0 area 0 ! ip access-list log-update threshold 1 ip default-gateway 10.5.5.1 ip forward-protocol nd ! ip flow-export source Loopback1 ! no ip http server no ip http secure-server ip route 0.0.0.0 0.0.0.0 10.5.255.1 ip route vrf Mgmt 0.0.0.0 0.0.0.0 10.5.5.1 ip route vrf Mgmt 10.5.7.0 255.255.255.0 10.5.255.2 ip ssh version 2 ip scp server enable ! ip access-list standard Access-ACL permit 192.168.50.0 0.0.0.255 log permit 10.5.19.0 0.0.0.255 log permit 10.5.5.0 0.0.0.255 log deny any log ! ! logging source-interface FastEthernet0 vrf Mgmt logging host 10.5.7.172 vrf Mgmt ! ! ! line con 0 logging synchronous line vty 0 4 access-class Access-ACL in vrf-also exec-timeout 120 0 logging synchronous autocommand terminal monitor autocommand-options nohangup transport input ssh line vty 5 15 access-class Access-ACL in vrf-also logging synchronous autocommand terminal monitor autocommand-options nohangup transport input ssh ! ntp server 10.5.7.35 ntp server 10.5.7.36 ! end
The only thing different really is I took the vrf off of this one
03-20-2020 05:05 PM
I still haven't found a solution for this. Does anyone have any ideas?
03-21-2020 08:52 AM
Thanks for posting the config. My first question is whether the switch is able to access the server where PRTG is running, using loopback interface as the source?
I note that the net flow destination address is 10.5.7.172. And I see a route for that subnet
but the route specifies vrf Mgmt and if I understand correctly you have removed that vrf.
03-23-2020 10:59 AM
Yes I removed the vrf. I can ping the server from that switch with a source of loopback1 and I can ping from the server to the loopback interface.
