Netflow not exporting after powering switches back up
I have a 3750G and 3750X which were both running Netflow and exporting to PRTG fine.  I recently powered them down and changed some interface configurations around, renamed both switches (basically I'm using the 3750x as a core switch now instead of an access switch).  Everything works fine, except netflow doesn't seem to export at all now.  I made no changes to the netflow configuration at all.  I've turned terminal monitor on and run "debug ip flow", "debug ip flow cache" and "debug ip flow non-forwarded" on both switches and I get nothing in the CLI.  Here's some example output from one of the switches:
#do sh ip flow export
Flow export v1 is enabled for main cache
  Export source and destination details :
  VRF ID : Default
    Source(1)       10.8.255.2 (Loopback1)
    Destination(1)  10.5.7.172 (9997)
  Version 1 flow records
  0 flows exported in 0 udp datagrams
  0 flows failed due to lack of export packet
  0 export packets were sent up to process level
#do sh flow export stat
Flow Exporter NetFlow-To-PRTG:
  Packet send statistics (last cleared 00:46:58 ago):
    Successfully sent:         0                     (0 bytes)
  Client send statistics:
    Client: Flow Monitor NetFlow-To-PRTG
      Records added:           0
      Bytes added:             0
#do sh run | s flow
flow record NetFlow-To-PRTG
match ipv4 tos
match ipv4 protocol
match ipv4 source address
match ipv4 destination address
match transport source-port
match transport destination-port
match transport tcp source-port
match transport tcp destination-port
match transport tcp flags
flow exporter NetFlow-To-PRTG
destination 10.5.7.172
source Port-channel1
transport udp 9997
flow monitor NetFlow-To-PRTG
cache timeout active 5
ip flow-export source Loopback1
ip flow-export destination 10.5.7.172 9997
Again, I have not changed any of the netflow config, outside of changing the source interfaces a bit just to see if I could get it to work.  I know it's not an IOS version issue because it was running fine before.  I tried running "clear ip cef * prefix" but that didn't seem to help either.
I'm kind of at a loss since I didn't touch any of the netflow config when I reconfigured the switches to swap the core and the access switch around.  Any help would be greatly appreciated.
5 REPLIES 5
So I've been reading up.  I've tried just about every solution I was able to find from other forums/articles, including changing the export interface to loopback, enabling route-cache, etc.  Still don't have a solution though.
Full config of one of the switches when everything was working
! Last configuration change at 21:23:23 EST Wed Feb 12 2020 by mvd
! NVRAM config last updated at 21:23:26 EST Wed Feb 12 2020 by mvd
version 15.2
no service pad
service password-encryption
hostname Asgard-Switch1
boot-start-marker
boot-end-marker
vrf definition Mgmt
 address-family ipv4
 exit-address-family
logging buffered 100000 informational
aaa new-model
aaa authentication login default local
aaa authentication dot1x default group radius
aaa authorization exec default local none
aaa session-id common
clock timezone EST -5 0
clock summer-time EDT recurring
switch 1 provision ws-c3750x-24
system mtu routing 1500
ip routing
no ip domain-lookup
ip domain-name Bifrost.local
vtp domain MikeNet.com
vtp mode off
 match ipv4 tos
 match ipv4 protocol
 transport udp 9997
archive
 path ftp://10.5.7.35/Asgard-Switch-1
 time-period 1440
dot1x system-auth-control
spanning-tree mode rapid-pvst
spanning-tree portfast edge default
spanning-tree portfast edge bpduguard default
spanning-tree vlan 5-7,50,297 priority 28672
spanning-tree vlan 19 priority 24576
vlan internal allocation policy ascending
vlan 5
 name Management
vlan 6
 name Access
vlan 7
 name Server
vlan 30
 name Dev-Env
vlan 50
 name Asus-Router-Subnet
vlan 297
 name Bornio
lldp run
interface Loopback1
 ip address 10.8.255.2 255.255.255.0
interface Port-channel1
 description Bond-To-Asgard-Core
 switchport access vlan 297
 switchport trunk allowed vlan 6,7,30,50
 switchport trunk native vlan 297
 switchport mode trunk
interface Port-channel2
 description Bond-To-Asgard-1-NAS
 switchport access vlan 7
interface Port-channel3
 description Bond-To-Asgard-2-NAS
interface Port-channel4
 description Bond-L3-To-Asgard-Core
 no switchport
 ip address 10.5.255.2 255.255.255.0
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip ospf dead-interval 3
 ip ospf hello-interval 1
interface FastEthernet0
 description Management
 vrf forwarding Mgmt
 ip address 10.5.5.2 255.255.255.0
 no ip route-cache
interface GigabitEthernet1/0/1
 description Link-L3-To-Asgard-Core
 no switchport
 no ip address
 channel-group 4 mode active
interface GigabitEthernet1/0/2
 no switchport
 no ip address
interface GigabitEthernet1/0/3
 shutdown
interface GigabitEthernet1/0/4
 shutdown
interface GigabitEthernet1/0/5
 description Mjolnir
 switchport trunk native vlan 177
interface GigabitEthernet1/0/6
 description S-NETMON1
interface GigabitEthernet1/0/7
 description Thor
 switchport access vlan 6
interface GigabitEthernet1/0/8
 description ARLO
 switchport access vlan 50
interface GigabitEthernet1/0/9
 description S-WINNIX
interface GigabitEthernet1/0/10
 description Aesir
interface GigabitEthernet1/0/11
 shutdown
interface GigabitEthernet1/0/12
 shutdown
interface GigabitEthernet1/0/13
 shutdown
interface GigabitEthernet1/0/14
 shutdown
interface GigabitEthernet1/0/15
 shutdown
interface GigabitEthernet1/0/16
 description Link-To-Asgard-1-NAS
 channel-group 2 mode active
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
 description Link-To-Asgard-2-NAS
 channel-group 3 mode active
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
 description Trunk-To-Asgard-Core
 channel-group 1 mode active
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
 shutdown
interface GigabitEthernet1/0/23
 shutdown
interface GigabitEthernet1/0/24
interface GigabitEthernet1/1/1
 shutdown
interface GigabitEthernet1/1/2
 shutdown
interface GigabitEthernet1/1/3
 shutdown
interface GigabitEthernet1/1/4
 shutdown
interface TenGigabitEthernet1/1/1
 shutdown
interface TenGigabitEthernet1/1/2
 shutdown
interface Vlan1
 no ip address
 no ip route-cache
 shutdown
interface Vlan5
 no ip address
router ospf 1
 router-id 10.8.255.2
 passive-interface default
 no passive-interface Port-channel4
 network 10.5.255.2 0.0.0.0 area 0
ip access-list log-update threshold 1
ip default-gateway 10.5.5.1
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.5.255.1
ip route vrf Mgmt 0.0.0.0 0.0.0.0 10.5.5.1
ip route vrf Mgmt 10.5.7.0 255.255.255.0 10.5.255.2
ip ssh version 2
ip scp server enable
ip access-list standard Access-ACL
 permit 192.168.50.0 0.0.0.255 log
 permit 10.5.19.0 0.0.0.255 log
 permit 10.5.5.0 0.0.0.255 log
 deny   any log
logging source-interface FastEthernet0 vrf Mgmt
logging host 10.5.7.172 vrf Mgmt
line con 0
 logging synchronous
line vty 0 4
 access-class Access-ACL in vrf-also
 exec-timeout 120 0
 logging synchronous
 autocommand  terminal monitor
 autocommand-options nohangup
 transport input ssh
line vty 5 15
 logging synchronous
 transport input ssh
ntp server 10.5.7.35
ntp server 10.5.7.36
end
The only thing different really is I took the vrf off of this one
I still haven't found a solution for this.  Does anyone have any ideas?
Thanks for posting the config. My first question is whether the switch is able to access the server where PRTG is running, using loopback interface as the source?
I note that the net flow destination address is 10.5.7.172. And I see a route for that subnet
but the route specifies vrf Mgmt and if I understand correctly you have removed that vrf.
Rick
Yes I removed the vrf.  I can ping the server from that switch with a source of loopback1 and I can ping from the server to the loopback interface.
Content for Community-Ad
