NETFLOW ON SWITCHES?
nikalleyne
Guys,
I have a C3560 (C3560-HBOOT-M) Version 12.2(25r)SE1, RELEASE SOFTWARE
MODEL  WS-C3560G-24TS-S
Would it be possibel to configure netflow on this device.
I don't see any ip route-cache flow command.
Looking forward to your answers.
Nik
Marvin Rhoads
Netflow is not suported on Catalyst 3560 switches. Cisco doesn't document it very well as far as I've seen.
Think of Netflow as primarily a router technology. While most switches also route, the access switches (such as 3560 series) don't have the support for Netflow built into them. 4500 and 6500 series switches handle it via add-on to the low end supervisors (i.e. NFFC for some 4500 supervisors) or high end supervisors (such as Sup-720 in 6500's)
This 3rd party link may be useful: http://www.manageengine.com/products/netflow/help/cisco-netflow/netflow-ios-versions.html
Also: http://support.caligare.com/kb/entry/42/
Hope this helps.
Marvin Rhoads
Hope this helps.
Thanks for the quick response.
fwilkins
Marvin,
We have Solarwinds Orion NPM\Netflow and it also works with IPFIX which is support on the Avaya 5500 switches.
